Sponsored by: Auxito
heater core
Old Mar 4, 2004 | 09:39 PM
xtrememtbkr's Avatar
xtrememtbkr
heater core
is the heater core in a 01 F150 under the dash on the passenger side? i noticed a gurgling sound[water bubbling?]
coming from that area after i shut off my truck tonight.
can't see any signs of a leak at all. anything to be
concerned about?
thanks
Old Mar 4, 2004 | 09:53 PM
dakota_viking's Avatar
dakota_viking
The heater core is located under the dash (WAY UNDER THE DASH). The reason you do not see anything leaking is because there is a catch pan/box to prevent fluids from leaking into the cab.
To replace the core, you pretty much have to remove the entire dash. Kind of a whole weekend project.....but cheaper to do it yourself than pay a shop 8 to 10 hours of labor.
Good luck with it,
Tim
Old Mar 4, 2004 | 10:07 PM
xtrememtbkr
i can't see any evidence of a leak anywhere. wouldn't it
be dripping onto my driveway? the anti freeze level is
staying constant, the defroster and heater work and there is no
a/f smell.could it just be a normal noise as it cools?
thanks
Old Mar 5, 2004 | 07:42 AM
dakota_viking
Sorry,
There I go typing before I finish reading
You may be correct, I you do not have that sickening sweet smell of anti-freeze coming out of the defrost vents, it may have just been the cooling process that you mentioned.
Sorry if I threw you into a panic for no reason.
Tim
