Bronco II Ford Bronco II
overheating?
Old Mar 4, 2004 | 06:50 PM
waywoos's Avatar
waywoos
overheating?
whats most likly the most common problem for overheating?
its about 80 degrees today and shes running very hot.
thanks
Old Mar 4, 2004 | 07:23 PM
Ken00's Avatar
Ken00
Low coolant, bad thermostat, clogged radiator, bad water pump, in that order. A missing shroud will give you problems and if it only happens when going slow a bad fan clutch.
Old Mar 7, 2004 | 11:02 AM
TimmyAbrams's Avatar
TimmyAbrams
I had your same problem when I used some cheap "Radiator No-Leak". It clogged up my thermostat. I took out the stock one (192 degrees) and stuck in a 180 degree thermostat. Now she runs quite cool. I'd highly recommend the 180 thermostat regardless of what you do.
Just look in the Haynes guide for your ploblems and woes.
Old Mar 7, 2004 | 01:16 PM
waywoos's Avatar
waywoos
awesome advice.
i think mine had that junk in it as well.
i seen the coolant color was more brown.
thanks for the 180 degree recomentation.
Old Mar 7, 2004 | 03:24 PM
87 xlt named donk's Avatar
87 xlt named donk
180* stat is the only way to go!
Old Mar 7, 2004 | 09:58 PM
Jrmobb's Avatar
Jrmobb
biggest disadvantage is it takes longer for my heater to warm up since it opens at cooler temp.
Old Mar 8, 2004 | 05:53 PM
waywoos's Avatar
waywoos
no biggie its summer now anyways.
Old Mar 10, 2004 | 09:05 PM
REB's Avatar
REB
IF NONE OF THEIR SUGGESTIONS WORK CHECK THE FAN CLUTCH
Old Mar 12, 2004 | 01:55 PM
Eric C.'s Avatar
Eric C.
Painless test for the fan clutch is to take a piece of heater hose and with the engine running see if you an stop and hold the fan. If you can bad clutch. I like direct drive and flexi fans my self. The brown is rust so do a flush and refill. Theres a two part flush that's actually citric acid that works best but be sure to neutralize it and do a goood clear water flush.
Old Mar 15, 2004 | 06:41 AM
waywoos's Avatar
waywoos
ok i put in new 180 and seems to work better.
i had a 195 degree in it.
is the 195 stock?
thanks for help guys.
Old Mar 15, 2004 | 11:38 AM
Jrmobb's Avatar
Jrmobb
yes at least im my 88 it was
