Inline 6cyl. HELP!!!
Old Mar 4, 2004 | 06:35 PM
topnotch50's Avatar
topnotch50
Exclamation Inline 6cyl. HELP!!!
I have a 1981 F100 Custom and was recently experiencing a sputtering troblem at acceleration.I replaced the Carb.,fuel filter,fuel pump,starter,starter relay,voltage regulator,all gaskets,and today a new performance coil.I have gotten it to start but it will not stay idle.I thought maybe "timing" and set it to spec via. Chilton by rotating the crank to 6 deg. BTDC and aligned rotor with the distributor.Now,as I turn the egine over it will not start and is blowing fuel form the top of the carb like it is burping it out.That's the easiest way for me to explain it.I'm lost and don't know what to do next.Can anyone please help me?
Old Mar 4, 2004 | 06:46 PM
BooBooBird's Avatar
BooBooBird
Unhappy
Interesting, I am having the same problem with an 84 L6 300. It cranks like the timing is off after a recent tuneup. On occassion it will start, but more often than not it will drag the battery down.
Old Mar 4, 2004 | 06:47 PM
BooBooBird's Avatar
BooBooBird
By the way, just in case the plug wires are crossed someplace, does someone know the firing order for the 300 L6?
Old Mar 4, 2004 | 06:54 PM
topnotch50's Avatar
topnotch50
153624 is the firing order.I have checked,rechecked,and checked again but I am getting the same effect.
Old Mar 4, 2004 | 06:58 PM
topnotch50's Avatar
topnotch50
I believe the order for the L6 300 is as follows: 1-4-2-5-3-6
Old Mar 4, 2004 | 07:04 PM
Chugalug's Avatar
Chugalug
1-5-3-6-2-4
clockwise
That is what Haynes says for 86 and earler l-6
Old Mar 4, 2004 | 07:12 PM
Chugalug's Avatar
Chugalug
87 and later is 1-5-3-6-2-4
but the cap is oreianted different .
Old Mar 4, 2004 | 07:17 PM
BooBooBird's Avatar
BooBooBird
Thanks everyone, I'll check that in the morning
Old Mar 4, 2004 | 07:24 PM
topnotch50's Avatar
topnotch50
What will make the fuel blow out of the carb while turning over the ignition?
Old Mar 4, 2004 | 07:28 PM
Chugalug's Avatar
Chugalug
I think a stuck intake valve uset to cause one to spit back through the carb.
I would mess with the timing and see if it changes anything.
Old Mar 4, 2004 | 08:20 PM
Slade901's Avatar
Slade901
Probably your camshaft gears is worn off and throwing the timing off.
Old Mar 4, 2004 | 10:04 PM
Chugalug's Avatar
Chugalug
Did you pull the number 1 plug and get the number 1 piston on the compression stroke?
Old Mar 5, 2004 | 08:05 AM
topnotch50's Avatar
topnotch50
The carb I bought the first time did the same thing so I thought I just got a bad rebuilt carb.I took it back and returned it for another and it is still doing the same thing.Another question though,to get the #1 cyl. TDC I took out the #1 plug,inserted a screw driver and manually turned the crank until the cylinder was all the way up,right before it going back down I stopped and set the distributor, I also tried it by Chiltons by turning the crank until the timing mark lined up 6deg. BTDC and set the distributor and I get the same results either way.
Old Mar 5, 2004 | 08:23 AM
Chugalug's Avatar
Chugalug
Do that again but cover the plug hole with your finger or thumb to make a good seal then turn the crank shaft till you feel pressure from the piston on your finger.
The piston may have to come up as many as 4 times to get it tdc on the compression stroke.
You can back the crank up if you have to, when it is close.
Old Mar 9, 2004 | 01:51 PM
topnotch50's Avatar
topnotch50
Sent it to the shop today.I tried everything I could and didn't get anywhere.I'll keep ya posted on the outcome.Thanks to everyone who replied!This one has really got me stumped!Can't wait to hear what the Mech tells me.
