i have been looking for cyclops, found all kinds of sites, nothing to do with veichles , finding ins co books on flowers etc etc. Do you have the link, to cyclops for what i want to do?/
Is their a wire under the dash that i can cut to put in a cut off switch. don't want to use # 22 fuse under hood with relay. just want to find a wire that will shut the motor off if it runing, and stay shut off till i hit switch again, I tried every wire on fuse box under dash , that don't work, engine keeps running, and the ignition wire at key is way too big. their must be some wire under dash that goes to computer that will work?? 1996 7.3 PSD
I really don't know what you're looking for either. Why cut a wire under the dash to shut off the engine when all you have to do is turn the key off??
If you're looking for a starter disable system, then there's hundreds of different ones out there. We sell the Karr system, Automate, and used to do one called Sabre. Car Toys, Circut City, Best Buy, and all the rest of the electronics stores sell starter interlock systems if that is what you're after.
I walked through the purchase section and it looked pretty simple and only $130 + sh... Looks like 1999 F-350/250 are only ones shown however, they also did not specify diesel vs gasser if I read it correctly. If they do 99 and up, sounds like a great little item! Another toy to install... Motorhaven ought to look them over... my .02
