93f150xlt 2wd
Old Mar 4, 2004 | 09:55 AM
93XLT150's Avatar
93XLT150
Thumbs up 93f150xlt 2wd
I just had some work done to the vehicle. It seemed as if the brakes were making noise. and it had that shuddering problem when accelerating. The dealership replaced three U joints and a center "something" bearing. That got rid of the shuddering. But the front end still makes noise even after they tightened the cross members? They said that they could lessen the noise but not totally get rid of it. Is there any way of totally getting rid of that popping noise that happens when I use the brakes??? Also there is whirring sound that seems to be associated with steering. Thanks in advance.
Old Mar 4, 2004 | 11:16 AM
brown 4x4's Avatar
brown 4x4
Check your radius arm bushings. They'll pop like that if they're worn out. You should also hear it whenever you hit a bump if they're really bad.
Old Mar 4, 2004 | 12:54 PM
93XLT150's Avatar
93XLT150
Thanks for the info - I'll check with the dealership to see what it is specifically that they did....
Old Mar 5, 2004 | 07:27 AM
93XLT150's Avatar
93XLT150
Popping noise when brakes applied
Here's what they did - do reduce the popping sound I was hearing - they dropped the crossmember, cleaned it up and reinstalled it.
For the shudderring - they replaced 3 U joints( are there only three or are there four?) - and replaced the center support bearing - This seems to have stopped the shuddering but the popping noise is still happening. Especially when I apply the brakes...
Thanks in advance.
