Sponsored by: Real Truck
Tires
Old Aug 25, 2001 | 09:59 AM
stumpy2's Avatar
stumpy2
Tires
Hello everybody, I have a 2k1 250 SD I lifted and now I want some bigger meats. Does anybody have an opinion on the Mickey Thompson Baja-MTX radials. Do they wear good, are you using them on your stock rims, what is the actual height in inches. I was also thinking about the Pro Comp All Terrains, same questions. Thanks all.
Old Aug 30, 2001 | 04:20 PM
Irondale90's Avatar
Irondale90
Tires
you have 10,000lb truck youl grind your $300 a piece mickies to the bone in 9 months, go with something with a higher tow rateing the procomps will wear better but if you want something radical try some Ground Hawgs. I've had a set on my sd f-250 for over a year with min. wear.
Old Aug 30, 2001 | 07:22 PM
Poolside's Avatar
Poolside
Tires
