battery not charging
Old Mar 3, 2004 | 10:02 PM
handx2's Avatar
handx2
i`ve replaced my battery,generator and regulator.my battery is still running down after about 3 days of opperation.the parts store told me that it could be the regulator fuse.do you think thats it?how do i know?what else could it possibly be?
Old Mar 4, 2004 | 12:19 AM
yota's Avatar
yota
most likly you have a dead short some where. disconect the pos cable with everything off, run a test light from cable to the battery post. if it lights you are using juice some where, (dead short) pull fuses 1 at a time till the light goes out. this is the bad circuit now you can test further. mine was the fan motor
Old Mar 4, 2004 | 07:08 AM
William's Avatar
William
Charge the battery over night on a 2 amp charge. Measure the voltage (carefully), should be about 12 volts. Put the battery in the truck and start it. Measure the battery voltage again, should be 13 + or - , but more than you had after charging the battery all night. Generator/regulator systems are marginal at best and you should determint that you have a system that is actually charging. Then follow the excellent advice of Yota and look for a drain. Another trick is to disconnect the battery and with everything turned off, slowly put the positive cable on the battery post and look for and listen for a spark. This tells you that voltage is flowing somewhere and with everything turned off there should be none. Or you can solve the problem once and for all by doing the GM one wire install per my instructions in the Tech Article section on this site.
