Sponsored by: Real Truck
SYNTHETIC LUBES
Old Nov 12, 2000 | 10:37 PM
rampage's Avatar
rampage
SYNTHETIC LUBES
I'VE HEARD SOME OF YOU GUYS TALKING ABOUT USING SYNTHETICS IN ADDITIONAL AREAS OF YOUR TRUCKS, SUCH AS THE DIFFERENTALS & TRANSMISSIONS. DO YOU HAVE ANY BRAND & PART # YOU CAN RECOMMEND. THANKS
Old Nov 13, 2000 | 03:29 PM
FTE Ken's Avatar
FTE Ken
SYNTHETIC LUBES
I've never heard anything bad about Mobile 1. You can get it pretty cheap (relatively speaking) at Walmart.
Ken Payne
Old Nov 13, 2000 | 07:49 PM
joecool's Avatar
joecool
SYNTHETIC LUBES
amsoil for the engine, diffs and transfer case, and if i remember either pj1 synth for trans or believe it or not quaker state, ill check but u cant go wrong with amsoil for the eng, difs and tc. amsoil is 100% synthetic oil where mobil1 still relys on the use of crude oils, very minute but they are still present and are subject to the same break down as std. oil. amsoil dosnt suffer that type of break down because it is completely enginered oil
Old Nov 13, 2000 | 08:19 PM
FTE Ken's Avatar
FTE Ken
SYNTHETIC LUBES
Mobile 1 is a fully synthetic oil created from polyalphaolefins and esters.
Ken Payne
Old Nov 14, 2000 | 07:26 AM
Steve R's Avatar
Steve R
SYNTHETIC LUBES
I used Amzoil in a '88 Suburban (glad it's gone) in the transmission, rearend and the motor. Great stuff! The only problem putting in egine every 3000 miles get expensive. I had to have the transmission rebuilt at 60000 miles, so when we put it back together Amzoil went in. I had the tranny service every 15000 after the rebuild with Amzoil replacing what oil was lost on service. I never had another tranny problem for the next 200,000 miles. It's going in to the real truck next service.
Steve R
'99 F250 5.4L CC LB 4x2
Old Apr 14, 2001 | 11:25 PM
heyvern's Avatar
heyvern
SYNTHETIC LUBES
My '99 4X4 V-10 has std 3.73 diffs. Ford came out with a TSB stating that if you changed you petrol based diff oil to synthetic, your tow rating would be increased by 1200 lbs. That would not be possible because the net tow rating is already surpassed, limited by the GCWR. But the point is, use it. I don't know if my mileage increased because of that, or my truck just started getting broken in. Just remember, there is an additive used in the locking diffs. Do not put it in a std diff.
Old Aug 25, 2001 | 06:28 PM
dave thomas's Avatar
dave thomas
SYNTHETIC LUBES
my ford dealer puts it in my truck
Old Aug 27, 2001 | 10:37 AM
webguyrich's Avatar
webguyrich
SYNTHETIC LUBES
[font size="1" color="#FF0000"]LAST EDITED ON 27-Aug-01 AT 11:37 AM (EST)[/font][p]Synthetic oil is much better if you are using your truck to haul or have increased it's performance. Synthetic oil will not break down as fast as conventional oil when it comes to heat. This is why most guys run synthetic in their engine, trans, and diff. Be aware that if you change your diff oil, you must also use the friction modifier from Ford if you have the limited slip diff.
I use Mobil 1 in my engine and trans, with Valvoline synthetic and friction modifier in the diff.
Rich
Old Aug 29, 2001 | 03:08 PM
dave thomas
SYNTHETIC LUBES
Dear Mr. Web,
I think my superduty comes standard with synthetic lube in the rearend. I had the pinion seal replaced at my dealer and I think he may have put the syn back in. I'm not sure but i should have asked to be sure. Do you know if they are required to replace it with the same lube?
Old Aug 29, 2001 | 08:01 PM
joecool's Avatar
joecool
SYNTHETIC LUBES
Yes, its factory specs now. but if you want to replace it ever, make sure that you use Amsoil, It the best synth out there, for all lubes, oils and fluids your truck needs. Remember its the best bar none! And im not only a member, im the president, only joking. Just a normal joe
Old Aug 31, 2001 | 03:52 PM
irvan01's Avatar
irvan01
SYNTHETIC LUBES
Old Sep 2, 2001 | 11:58 AM
tinman_r75's Avatar
tinman_r75
SYNTHETIC LUBES
i think amsoil is boss too
Old Sep 2, 2001 | 10:19 PM
dave thomas
SYNTHETIC LUBES
tinman you are so cool you must know a lot about oil
