Bronco II Ford Bronco II
89' BII heating problem
Old Mar 3, 2004 | 08:33 PM
Loser84's Avatar
Loser84
if you look head on at the engine(from the front) to the right and the top most pully compressor. I believe that is what is causing my problem. I will hear a click sound and then the wheel stops turning. a couple minutes later it will start back up.? what is it. and how do i fix it
Old Mar 3, 2004 | 10:49 PM
mrshorty's Avatar
mrshorty
I'm guessing that's your air conditioner compressor. And from your description, it sounds like it might be seized. If so, you can either fix it by replacing the AC compressor or "fix" it by removing the AC belt or unplugging the compressor.
Old Mar 4, 2004 | 07:02 AM
Loser84's Avatar
Loser84
how much. would the air compressor cost?
Old Mar 4, 2004 | 10:31 AM
mrshorty's Avatar
mrshorty
Three major parts suppliers have online catalogs. Check www.partsamerica.com www.autozone.com www.napaonline.com I would guess it will run you on the order of a couple hundred dollars.
Old Mar 4, 2004 | 04:24 PM
CrazyFazy's Avatar
CrazyFazy
Dont know if this could be it or not but someone told me if you were low on freon the compressor will kick off and on constantly. Mine did it and I just unplugged it.
