Autolite AP45 vs AP46?
Old Mar 3, 2004 | 07:07 PM
BigShelby's Avatar
BigShelby
I just tuned up the truck and I'm still not satisfied with the amount of pinging at higher RPM or under a load such as going up a hill. I did notice that I got a set of plugs one number hotter than the old ones, Autolite AP45 vs AP46. Would this make a noticeable difference in the pinging I'm experiencing? Points are gapped at .35.
I replaced the wires, cap, rotor, points (properly gapped .17) and condenser at the same time. Timing verified at 10 degrees. Also am running 93 octane. On 87 it pings worse. I know I could reduce the timing but then it will really be a dog. Pinged about the same before tuneup. I thought the new goods would cure this.
Does anyone think that getting rid of the points and going with a Petronix, Mallroy or Crane conversion would eliminate this problem since it seems to be happening at the high end only where the points are more prone to error?
TexasMarkIII
Apr 22, 2016 02:08 AM
ron reece
1997 - 2003 F150
Oct 7, 2007 06:07 PM
Shawn MacAnanny
Feb 21, 2007 10:27 AM
signalius
Jan 16, 2004 06:17 PM
john
Jan 4, 2000 06:46 PM
