oil pan removal
Old Mar 3, 2004 | 06:17 PM
sthrnredneck's Avatar
sthrnredneck
oil pan removal
I have a 1990 F150 with a 5.0 302cid EFI and i think the oil screen is stopped up or the pump is bad. Could any of you tell me how to remove the oil pan, and do i have to jack the motor up to do this.
Old Mar 3, 2004 | 08:13 PM
sty's Avatar
sty
According to Chiltons: Unbolt motor mount ,jack up with a block of wood to disperse the weight , use another piece of wood to maintain the clearance , then access the oil pump pickup tube, remove the 2 bolts attaching the oil pickup tube to the oil pump,remove the nut attaching the oil pickup tube to the No.3 main bearing cap stud, remove pan.
Hope this helps!
Sty
