flow matched injectors ?
Old Mar 3, 2004 | 12:43 PM
ferguson777's Avatar
ferguson777
Where can I get 19 lb. flow matched injectors?
These are for a mild SD-EFI 1990 F150 302. Summit carry two brands - Ford Motorsports (which are clearly stated - must be used with modified MAF-EFI) & the Venom brand.
Are the venom brand o.k.?
Accel also offer them but they seem pricey.
Need to buy new injectors anyway, and just want to ensure I squeeze every last ounce of efficiency out of this engine.
Thanks,
Old Mar 3, 2004 | 12:46 PM
EPNCSU2006's Avatar
EPNCSU2006
I don't see why the FMS 19lb/hr injectors won't work. I think that comment is to make sure people know that maf vehicles must have an air meter calibrated for the injectors. As long as they have the same resistances as stock injectors, there shouldn't be any trouble running them.
Old Mar 4, 2004 | 05:11 PM
ferguson777
Thanks but does anyone know anything about the Venom brand or know of a place to get flow matched 19 lb. injectors?
Old Jun 10, 2004 | 01:52 AM
"Beemer Nut"'s Avatar
"Beemer Nut"
Injector flow and tester
I sent a friend to www.cruzinperformance.com, he got a matched flow set of injectors for a 89 Dodge van, 318 engine. It never ran as good as it does now.
Go on Google and type in, JetorRate. Use the one , Electronic Fuel Injector Tester By Bowling and Grippo. They have plans for a electronic pulser to clean and flow test your own injectors. I'm in the process of building one myself. My $.02. Carl. ...............................o&o>............... ............................
Old Jun 10, 2004 | 09:27 PM
LxMan1's Avatar
LxMan1
The Motorsport(FRPP) 19lbs injectors will work fine when replacing 19lb injectors. The 24lb injectors need a modified MAF and ECM to have the correct pulse width.
Old Jun 11, 2004 | 07:44 PM
"Beemer Nut"
I found a good source for injectors today, outright and cheap.They go by manufacture, primary casting number and secondary number as well as flow tested and group matched. www.injector4u.com. $34.99 x 8 is alot better than $189 x 8 for my 4.6 litre Rover, ya think! I'll use them when I build my MPI system for the 68 F-250 with 481 CI FE engine. Hope this helps, Carl. ...................o&o>......................
Venom76
Large Truck
Jan 3, 2021 11:33 PM
fairlaniac
Jun 1, 2005 06:22 PM
Venom_Fang_16
Engine Swaps
Nov 22, 2004 10:31 AM
wantaford
Nov 5, 2004 10:39 PM
venom69
May 26, 2003 02:01 PM
