windsheild chrome trim help
Old Mar 3, 2004 | 08:06 AM
faslane's Avatar
faslane
i bought a 68 f100 and when i got it the chrome trim on the right side on the windsheild was off. the rubber around the windsheild has a groove, and the chrome has a L shaped notch on the back, i have tried everthing to get this back on. i even messed up one peice and i thought i would ask before i tore up the new piece. is there a secret to getting the chrome back on... thanks
Old Mar 4, 2004 | 11:36 AM
Aekisu's Avatar
Aekisu
<cr>
It would seem someone would have an answer.
I can tell you that on a VW, you install the trim in the rubber. Then you put the rubber around the windshield. The last step is to install the windshield.
Old Mar 5, 2004 | 10:59 AM
Carlene's Avatar
Carlene
Admom
Hey Faslane - welcome to FTE.
I'm moving this to the 1968 Truck forum. Maybe one of the guys there can help you.
Good luck with your project.
Old Mar 5, 2004 | 11:11 AM
Highboy70's Avatar
Highboy70
Well, sad to say the windshield has to be removed to get the chrome in. The trim is placed in the groove before the windshield goes in place, and the force of the cab against the rubber is what holds it in. Sometimes when the rubber gets cracked and hard a piece will pop out.
I have tried to install one of these myself to no avail. I would HIGHLY recommend taking in to a knowledgable glass shop.
Old Mar 5, 2004 | 04:43 PM
idealtrucks's Avatar
idealtrucks
when i had mine done, the glass shop tried forever to get mine back in a finally got it, so it is definatley a job for a pro
Old Mar 5, 2004 | 06:36 PM
faslane's Avatar
faslane
thanks for all the info guys, i knew there was somthing mor to it. i will take it to a glass shop monday, thanks again..
