Sponsored by: Kumho
rim size
Old Mar 2, 2004 | 07:50 PM
ltzf250's Avatar
ltzf250
rim size
Right now i have a dana 44 with drum brakes. The rims I have are 15in. I am wanting to upgrade to a dana 60 with disk brakes. Am i going to have to get bigger rims? Thanks
Old Mar 3, 2004 | 06:10 PM
Lou Braun's Avatar
Lou Braun
Almost certainly. When you look at the new axle, try fitting a 15" rim over the brake calipers. Then you would know for sure.
If you are going to all the work of swapping axles and brakes (!), I'd recommend that you get heavy duty 8-bolt rims at the same time.
Lou Braun
