Powerstroke smoke!!
Old Mar 2, 2004 | 06:51 PM
getirdone's Avatar
getirdone
Powerstroke smoke!!
Does anyoen know why the new 6.0L dont smoke as much as the old powerstrokes? or why the cam bearings and scensors are going out easier? also does anyoen know why a nonturbocharged diesel is better? or is it?
Old Mar 2, 2004 | 07:12 PM
jdadamsjr's Avatar
jdadamsjr
You didn't say better for what... but
I can't imagine a non-turbocharged diesel being better--- for
anything !
Just disconnect the turbo hose and see how much you like it !
And as far as smoking -
Isn't smoking just unburned fuel ????
the 6-oh does have an EGR system AND a catalytic convertor,
it is much more computer controlled,
and doesn't dump so much fuel that it DOES smoke,
or at least burns it ALL up before going out the exhaust...
but if you want some smoke -
get the predator and put it in the +100HP setting and FLOOR it ...
it doesn't smoke a lot, but does some... and goes !!!
my 02 7.3 with the superdhips used to smoke a LOT !!!
Old Mar 2, 2004 | 07:17 PM
getirdone's Avatar
getirdone
do you haev any idea why the cam bearings and scensors go out so easy on the new 6.0L?
Old Mar 2, 2004 | 07:20 PM
jdadamsjr's Avatar
jdadamsjr
actually ,
you're the first to mention that on the 3 ford diesel sites I visit....
and I've not had a problem...
Old Mar 2, 2004 | 07:24 PM
tn mac's Avatar
tn mac
because is trying to get to much out of the engine, is my feeling. My 2000 7.3 didnt smoke any more then my 6.0 powerjoke.
Old Mar 2, 2004 | 07:25 PM
Choctaw Bob's Avatar
Choctaw Bob
Have not seen a complaint on cam bearings and sensors. Sounds like a Dodge or Chevy rumor.
Old Mar 2, 2004 | 07:28 PM
jdadamsjr's Avatar
jdadamsjr
My 7.3 OR 6.0 didn't smoke at all
UNTIL I got a module...
and I'm sure one of the functions is to dump more fuel to the point of too much to burn ---
Old Mar 3, 2004 | 10:13 AM
Vic_Ferrari's Avatar
Vic_Ferrari
Diesels make power with more fuel (among other things).
Running a gasoline engine richer usually results in a loss of power....not so with a diesel...
Diesels run out of AIR....and this is where power gets limited.
You can fuel them until they choke....and thats fine if enough air is coming in. Adding fuel and seeing a little smoke is ok, but at a certain point you will need to increase airflow (like rasing boost on the turbo).
Can you run them so rich they lose power......yes, but it takes a fair amount of fuel to do this.
Remember....fuel also keeps the cylinders cool and EGT's low.
Old Mar 3, 2004 | 10:43 AM
jdadamsjr's Avatar
jdadamsjr
makes sense Vic...
as soon as I bring mine in for the last dealer visit to fix some 'stuff" they didn't do... I'm getting an intake to go with my exhaust...
I don't need no stinkin smoke
Old Mar 4, 2004 | 09:14 AM
getirdone's Avatar
getirdone
smoke is the best part of a diesel your crazy
Old Mar 4, 2004 | 12:37 PM
FordRuss's Avatar
FordRuss
When the shop-diesel site updated their message forum, there were lots of complaints about the CPM (Cam Position Module) on the 6.0's. From reading the numerous Posts about the subject, it would appear to be a high fail item. Most of the Posters recommended keeping a spare in the glove box along w/ a 10mm wrench for changing it out. Most of the symptoms were sudden loss of power & being left on side of the road. Sometimes they could restart it & get home, other times they couldn't..
Russ
Old Mar 4, 2004 | 02:22 PM
jdadamsjr's Avatar
jdadamsjr
WHAT - I heard that - but I thought it was on the 7.3's ???
Old Mar 4, 2004 | 04:10 PM
FordRuss's Avatar
FordRuss
Nope, It was the new 6.0's and didn't seem to matter what the build date was.. Glad they got the injector problem cleared up though..
Russ
Old Mar 4, 2004 | 04:22 PM
jdadamsjr's Avatar
jdadamsjr
oh well... my Apr 03 build date runs like a rocket and narry a hiccup...
wll just keep my head in the sand and enjoy it I guess !
Old Mar 4, 2004 | 04:24 PM
Choctaw Bob
Me too! I just loaded the 100 HP mode so the truck will be ready for Sunday!
