wheel squeeeeeek
Old Mar 2, 2004 | 05:44 PM
19903024x4's Avatar
19903024x4
wheel squeeeeeek
it sounds like its comming from one of the wheeles but it squeeks when i drive...when i make a right turn it stups but going straight and on left turns it still does it...any ideas?
Old Mar 2, 2004 | 06:09 PM
frederic's Avatar
frederic
The brake pads are rubbing on the rotor
*or*
One of the wheel bearings is shot.
Regardless which it is, repair both sides so the are even.
Old Mar 2, 2004 | 06:30 PM
19903024x4's Avatar
19903024x4
well i did just do the brakes a few weeks ago but this just started....i'll do the bearings to be safe..thanks for the help!
Old Mar 10, 2004 | 12:44 AM
missouguy's Avatar
missouguy
You might check the wear indicators on the new brakes. If you bend them they will rub the rotor and you think your pads are worn out. I bet that is it.
Frank
