Light Problem
Old Mar 2, 2004 | 01:32 PM
rhyno8's Avatar
rhyno8
Light Problem
Hey, I am having problems with my trailer signal lights when towing with my 93 Ranger. The signal lights will not work on the trailer unless I push the brake pedal. I checked the trailer to make sure that it wasnt the problem and they work fine with my other vehicle. I bought a new wiring harness with the T adapter to just plug in but after installing it I still have the same problem. The signal blinks fast in the truck and not on the trailer at all until you hit the brake pedal and presto I have signal lights again. I know the easiest fix is to just brake before I signal! Any ideas?? Thanks.
Old Mar 2, 2004 | 01:39 PM
Lone_Ranger01's Avatar
Lone_Ranger01
Check all the grounds on your trailer wiring on your truck. Inspect all the wires to make sure they're in good condition and no shorting out or corroded. I don't know too much about the wiring but it sounds like a possible grounding issue. Some of the other guys on this forum should help you figure out the prob.
Old Mar 2, 2004 | 02:05 PM
ranger88a's Avatar
ranger88a
You have separate turn and brake lamps on your ranger. You need a converter on the pickup to make the circuit work on the trailer properly. You can get one from any parts store to work on your ranger.
Old Mar 3, 2004 | 07:02 AM
rhyno8's Avatar
rhyno8
I bought the T connector wiring harness that was made for Rangers. I would have thought that if a convertor was needed it would have came in the T connector. But I will give it a shot. Thanks.
Old Mar 3, 2004 | 07:58 AM
ranger pat's Avatar
ranger pat
Veteran: Navy
You need a "trailer tow relay". Small plug in relay that powers the turn signals. Otherwise, the turn and brake signals merge together through the wiring harness.
