Originally posted by fornarog Great suggestion, Thanks!
I still am unsure whether I need the rear mount or side mount unit. At the risk of appearing INCREDIBLY STUPID is there an easy way to determine this?
Thanks!
The side unit goes along the driver's side under the bed directly behind the cab just inside the frame. The rear unit sits in between the frame rails behind the rear axle.
