Sponsored by: Real Truck
99 CC trailer wiring problem
Old Oct 9, 2001 | 02:30 AM
surfbark's Avatar
surfbark
Hi all,
I am having trouble with my factory trailer wiring. I cant get my right turn signal/brake light to work at the plug next to the spare tire. I have checked it up to the underhood fuse box, and checked all the fuses in the truck, but to no avail.
Any thoughts?
Also, does anyone know where the trailer brake controller wiring is inside the truck?
Thanks much
Old Oct 9, 2001 | 02:08 PM
red99sdv10's Avatar
red99sdv10
As far as the brake /turn light there is a fuse under the hood for that , double check the wires at the plug on the frame by the spare tire .
the EB controler wire harness is under the dash above the heater outlet on the center hump
it is kinda hid so you need to look hard for it
Old Oct 9, 2001 | 04:07 PM
scottincincinnati's Avatar
scottincincinnati
