Howdy,
I have noticed that whenever i try to turn while I am at a stop, or slow speed that my truck doesn't like to turn. In fact at a dead stop i cannot turn at all. I checked the fluid levels and power steering seems to be ok. What else can I do?
Mud .. If there isnt fluid leaking from the steering box and if the belt isnt slipping or the pulley slipping on the shaft, there isnt much to do except change the pump. You could find someone who has a high pressure guage and check the pressure being made at the pump to make sure the pump is ok (or not).
Really sounds like to me that your belt is slipping. I have to use a belt that has teeth if ya will on it so that mine does not slip when iam at a dead stop with the snowplow on the truck.
