Oil Leak Rear Main Question
actually the rear main seal is a ton of work. the trans has to come out because you have a one piece seal. i got a price of 600 and parts. more than likely it is not your rear main but it probably is the oil pan gasket. clean it up real good and get into the investigation and make absolutely sure where the leak is. i also thought i had a rear main seal leak and upon a real good investigation i saw it was the oil pan gasket. this is also a big job but i did it myself in 6 hours and saved the 350 dollars labor.
the oil pan gasket usually starts leaking in the rear and you would not be the only one fooled. a good cleaning and investigation will help you find the leak but i doubt it is the rear main.
