Interior Trim
Old Mar 1, 2004 | 06:04 PM
Fully_Loaded's Avatar
Fully_Loaded
Question Interior Trim
On my 91 XLT Lariet I need to know what the trim piece is called where the fuel selector switch, Headlights, Wipers, and overdrive switch are. I need a new one and don't know what to call it.
Old Mar 1, 2004 | 06:10 PM
frederic's Avatar
frederic
Re: Interior Trim
The part that goes around the cluster, where the headlight switch and fuel tank switch are (and the air conditioning vents)
is called a cluster shroud, and you can get it from the dealer, or any 92-96 bronco, F150, F250, F350 and F450 in the junkyard.
The plastic pieces that surround the steering column, is two halves, and upper half and a lower half, and called 'steering column trim'. Also, a junkyard item.
Good luck!
Old Mar 1, 2004 | 06:24 PM
Fully_Loaded
Thanks a lot I appreciate it
Old Mar 2, 2004 | 07:39 PM
zieg96's Avatar
zieg96
There is one being parted out in the classifieds 1991 xlt
