Technical Question..........
Old Mar 1, 2004 | 12:14 PM
PSD6litre40's Avatar
PSD6litre40
Engine is surging at Highway Speed. I was told that the Rotella oil I am running could be the cause. Because the injectors are hydraulically controlled. Is this true? I am changing the oil tonight to the MOtorcraft Oil to see if this is the cause. What do you all think.
Old Mar 1, 2004 | 02:09 PM
SBV45's Avatar
SBV45
I don't think it is the Rotella. I would check oil level. There are a bunch of previous posts on oil levels and oil changes. Your oil should be inbetween the min and max markings.
The 6.0 doesn't have a divider between the crancase oil and the crank. Too high an oil level will create foaming.
Old Mar 2, 2004 | 09:24 AM
PSD6litre40
you mean a windage tray? And, yes I know about the foaming. But, still that doesnt make much sense.
Old Mar 3, 2004 | 07:43 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Yes a windage tray, if the oil foams it causes a loss in function of the injectors. Foaming oil will not allow the injectors to operate properly. It can result in surging……IMO
Old Mar 3, 2004 | 10:49 AM
jdadamsjr's Avatar
jdadamsjr
Many run the Rot-T witout incident... including me...
and if mine where foaming I would think it would REALLY foam when the +100HP predator kicks in....
I agree it's more the oil level possibility...
Old Mar 5, 2004 | 06:09 AM
flounder's Avatar
flounder
I had a ford rep tell me that not to use delo or rotella because it does not have foaming characteristics and that I should use Motocraft oil. I guess that is the right thing to hear from a ford rep right? So why would he recommend a oil with foaming characteristics if you guys are say no? I looked at both oils and all have proper rating for this motor and see no problems with the delo or rotella. Think he may be full of it.
Old Mar 5, 2004 | 06:50 AM
IB Tim's Avatar
IB Tim
Many have said that, it is one of the reasons that
Mobil Delvac 1 is so popular.
The 6.0 is sensitive to foaming
Old Mar 6, 2004 | 07:10 AM
PSD6litre40
changed oil and still is surging.................
Old Mar 6, 2004 | 08:05 AM
IB Tim's Avatar
IB Tim
To what type, do you have a black distick end or the gray one
