Transmission Question
Old Mar 1, 2004 | 06:32 AM
hostile413's Avatar
hostile413
Is there a sticker on the door to tell what type of tranny you have?...Or any way to tell?...I have a 95 F-150 with a straight six and its a 5speed. Any help would be great...Thanxs
Old Mar 1, 2004 | 12:16 PM
FordPerf300's Avatar
FordPerf300
You most likely have the Mazda M5R2, you can tell easily by crawling under the truck and looking at the tranny it's self. The mazda will have horizontal and verticle ribbing on the side of the case. The other tranny option would be the ZF S542, which has diagonal ribbing on the case and also two PTO plates on the very bottom, also the ZF is a beast of a tranny, much larger than the mazda.
Old Mar 1, 2004 | 12:56 PM
MustangGT221's Avatar
MustangGT221
The mazda was also more known for being called the M5OD..and there are two ZF's...a S5-42 and S5-47...one rated 420ft-lbs and the other 470. Another way to tell is if you can go above 15 in 1st gear...it's the mazda. The ZF has a very low (called granny low) first gear.
Old Mar 1, 2004 | 09:13 PM
hostile413's Avatar
hostile413
my tranny has a number on the drivers side thats says....F1TA.....the drain plug is also on the same side...so im takin it that i have the mazada tranny?
Old Mar 1, 2004 | 09:17 PM
acerockola77's Avatar
acerockola77
It's the M5OD, they only put the ZF in the 1/2 tons in 88.
Old Mar 2, 2004 | 06:39 AM
hostile413's Avatar
hostile413
thanks for the help guys
