speedometer/odometer not working
Old Mar 1, 2004 | 05:17 AM
acastignetti's Avatar
acastignetti
Can anyone give me info on the wire code/color for the speedmeter/odometer pickup wire? Also where is the speed sensor located? My odo is not working on my 03 expy and I would like to troubleshoot.
Old Mar 1, 2004 | 09:53 AM
ms6073's Avatar
ms6073
When you say the odometer is not working, does this mean that the digital display intermittent or blank but the mileage indication continues to increment correctly or that the odometer is no incrementing? If the odometer is working correctly but the display is intermittent or blank, then maybe this thread will help: Blank Odometer fixed...
Michael
Old Mar 1, 2004 | 11:53 AM
acastignetti
Both the speedometer and odometer are not working. I assume it is a faulty/loose connection. Do you know the wire color codes, or connector locations for this circuit?
Thanks,
