Sponsored by: Real Truck
Customer Circuit Access??
Old Oct 15, 2001 | 03:29 PM
TexanF250's Avatar
TexanF250
Hello,
I just got a 2001 F-250 V-10. Iam wanting to install an amp in the truck. I looked under the dash and saw a set of wires with nothing pluged into it. There is a label that says "Customer Access Circuit" I checked fr power and there is none there. Do I need to put a fuse in some where to get that live?
Thanks for the help!
Chris
Old Oct 15, 2001 | 05:13 PM
powerstroker250's Avatar
powerstroker250
Those wires are for running stuff thru the firewall. They terminate in the engine compartment near the brake booster.
Les
Old Oct 17, 2001 | 10:23 AM
red99sdv10's Avatar
red99sdv10
those wires arent heavy enought to power a stereo amp. get the power right from the battery
Old Oct 18, 2001 | 10:04 AM
Lashlaroo's Avatar
Lashlaroo
Old Oct 19, 2001 | 10:19 AM
harald's Avatar
harald
Next to those customer access wires is also a switched 12volt circuit, but it's a small wire. I'd ditto the above suggestion to run straight off the battery with larger wire. Optimally, you could use the switched wire to activate a relay that powers your amp.
2000 F350 CC DRW Lariat 4x4 LWB 4R100 V10 4.30ls with Torklift tie-downs/Superhitch and Rancho RS9000 and Ride-Rite air springs.
1998 Alpenlite Pendelton 11'10" Slide-in camper with all options.
2012 F250 6.2
Aug 29, 2021 09:54 AM
dank4120
Dec 6, 2015 06:32 PM
JTChandler
Oct 12, 2015 09:10 AM
I.B. Washincars
Feb 15, 2009 05:38 PM
PeteC
Apr 22, 2002 01:11 AM
