eh? Some of it has little or no cost of power, such as the charcoal canister. Unless you are removing the EFI, you will probably make it run like crud by removing misc smog devices. Don't screw up the environment just for the hell of it.
most engines are designed to run correctly with all parts still on, if it works leave it. Most think they gain horse by removing, but ultimately cause larger problem later on. not worth the 2 horses at the pulley.
Yea,
their right blue fan. If your looking for HP, there are many things you can do, but your not going to feel any seat of the pants gain by disconnecting the smog equipment. Check out some of the threads throughout the performance section. Many HP improvments have been done based on a budget in mind.
