390 Carb choice
Old Mar 13, 2004 | 05:35 PM
4x4madness's Avatar
4x4madness
After I nail the gas and it starts to wind up it will backfire, one other thing, a guy I work with came and admired my work and told me that I should rip off the EGR valve and put a plate over it and take and plug the valve in the manifold. Well I just plugged them off and the truck seems to run like crap wont idle severe hesitation and I checked the timing and reset it and checked the vacuum and it is barely 15"Hg <--- Checked by pulling the brake booster line and attaching my guage there, is that right? One last thing I live in Montana where there is no emission controls so anything goes.
Old Mar 15, 2004 | 10:26 PM
Putt's Avatar
Putt
That is the correct vacuum reading--the EGR is vacuum controlled. Did you plug the vacuum line that was hooked to it?
Is it an exhaust backfire or thru the carb?
Old Mar 16, 2004 | 03:59 AM
4x4madness's Avatar
4x4madness
It feels as though the backfire is in the carb and I removed the EGR valve and fabricated an 1/8" steel plate to go where the valve bolted up. One other thing, the engine was reman. probably 8k ago and I cant seem to keep it in time I always set it at 12 degrees BTDC and after I rod it a little bit it will end up at about 2 to 6 degrees <---- Worn out distributor or chain <--- Both?
Old Mar 16, 2004 | 08:59 AM
78fordman's Avatar
78fordman
I use a edelbrock 750 4-v, i get about 13MPG and have a lot of power when i need it. Probably overkill, but i like it that way.
