351W EFI conversion.
Old Feb 29, 2004 | 11:17 AM
bremen242's Avatar
bremen242
Question 351W EFI conversion.
I want to convert my '85 351W to EFI. What would be the easiest way to swap on EFI? Mustang EFI, truck, or cob something together from a early '80s grand marq? I need something that would be able to pass emissions (but not CA emissions though) at least.
Old Feb 29, 2004 | 07:09 PM
There Goes The Neighborhood's Avatar
Contact Holley, and your problems are solved.
Old Feb 29, 2004 | 08:52 PM
bremen242's Avatar
bremen242
You mean for their ProJection system? I looked at that, but I wondered if it was smog legal. It would be great since you can bolt it on to a regular 4bbl intake..
I was thinking along the way of ford factory, but the projection would work if it was smog legal..
Old Feb 29, 2004 | 08:56 PM
I believe that had it has a CARB exemption number, making it emissions legal, even in CA. Someone correct me if I am wrong.
Old Feb 29, 2004 | 09:15 PM
bremen242's Avatar
bremen242
that would be the ticket then.. need to figure out the smog pump and etc though.
Old Feb 29, 2004 | 09:19 PM
I'm pretty sure there is no smog pump, and if there is on the truck currently, run it to where it runs now. It won't hurt power, and it should act just like an air scrubber on wheels. JK, but it won't hurt to leave it on, and if it doesn't work no(smog pump) don't worry about it, it doesn't do that much.
Old Feb 29, 2004 | 09:23 PM
bremen242's Avatar
bremen242
yeah, I know.. I have to figure how to hook it up, since they do a visual here
Old Feb 29, 2004 | 09:27 PM
I feel for you. Here in central Il, they don't care if you run an IHRA Pro Stock engine, as long as the exhaust doesn't exceed the cop's liking.
Old Feb 29, 2004 | 09:48 PM
bremen242's Avatar
bremen242
that is the way it used to be here.. that's all changed...
Old Mar 1, 2004 | 12:50 PM
MustangGT221's Avatar
MustangGT221
Check the local law I believe u only have to be emissions legal for the year of your vehicle, so the emissions of the EFI motor would have to be atleast equal to the carb or less. That isn't hard at all with EFI
kuzco
Oct 14, 2009 05:46 PM
colemanw
Dec 25, 2008 12:54 PM
jdhudall
Aug 16, 2006 09:56 PM
mudadiction
Feb 28, 2006 12:37 PM
mhaskell
Engine Swaps
Oct 20, 2004 07:04 PM
