Engine code 33
Old Feb 27, 2004 | 09:08 PM
christaylor's Avatar
christaylor
Engine code 33
Pulled the codes on my 95 Explorer and got code 33. Which the book tells me is "EGR valve fault / not closing properly / TPS fault (Diesel)
I have replaced the EGR valve and sprayed throttle body cleaner into the tubes. The light came back on after the engine was warmed up. After a short trip then restart the light stays off.on short trip back home. I have already unhooked the battery for about a 1/2 hour to reset the computer. What am I Missing??? i have not had a chance to re pull the code but this is the second time I have pulled the EGR valve to check and gotten the code again.
Any help appreciated
Chris
I am going to post this in the Explorer forum also
Old Feb 27, 2004 | 10:31 PM
mrshorty's Avatar
mrshorty
go through the pinpoint test properly. Usually the EGR position sensor (DPFE?) circuit is having the problem rather than the EGR valve itself.
Old Feb 27, 2004 | 10:37 PM
christaylor
What do you mean by pinpoint test and where is the EGR position sensor? Sorry to ask stupid questions just don't have too much experience with this engine.
Chris
