Pulled the codes on my 95 Explorer and got code 33. Which the book tells me is "EGR valve fault / not closing properly / TPS fault (Diesel)
I have replaced the EGR valve and sprayed throttle body cleaner into the tubes. The light came back on after the engine was warmed up. After a short trip then restart the light stays off.on short trip back home. I have already unhooked the battery for about a 1/2 hour to reset the computer. What am I Missing??? i have not had a chance to re pull the code but this is the second time I have pulled the EGR valve to check and gotten the code again.
Any help appreciated
Chris
I am going to post this in the 4.0 forun also
Unplug vacuum line and apply vacuum to the nipple of the EGR. The hose at the ERG does not have vacuum to it, unless the cumputer calls for it. Does this help? Let us know.
