timing
Old Feb 27, 2004 | 07:17 PM
mouthahoy's Avatar
mouthahoy
timing
I was wondering if someone could tell me how to set the timing on a 302 motor. Thanks
Old Mar 1, 2004 | 01:06 AM
Superdave's Avatar
Superdave
mouthahoy
What year?
Old Mar 1, 2004 | 02:32 PM
mouthahoy's Avatar
mouthahoy
1986 f-150.
Old Mar 1, 2004 | 10:51 PM
Superdave's Avatar
Superdave
mouthahoy
Do you still have the decal on the core support with this info on it?
Old Mar 2, 2004 | 02:42 PM
Superdave's Avatar
Superdave
mouthahoy
I had an 86 Bronco years ago, with the 302, I'm thinking it had the spout connector by the distributor that needed to be unplugged. And the base timing setting was 10 BTDC.
This spout connector is a little grey plastic looking plug, it should be in the area of the distributor. It will be a couple of wires that just dead end with this plug in the connector at the end of it. Unplug it before you do any timing adjustments. Hook your timing light to the number #1 plug wire. Check the timing with the engine running and warm.
