92 Explorer strange sounds
Old Feb 27, 2004 | 01:30 PM
ekelly's Avatar
ekelly
Unhappy 92 Explorer strange sounds
The other day, my wife was driving home our 92 Explorer XLT 4X4 and it started making funny noises like a Kenworth diesel when she would let off the gas going downhill. It seemed to slow the vehicle down like brakes were sticking or something. I haven't checked it out yet but was hoping for some input from this fine forum on where to start looking. She still drives it around town but is afraid to take it off the mountain because of hills and braking. Could it be brakes, or abs, or trans, or u-joints, or hubs, etc???????? Where would you start.........
Old Feb 27, 2004 | 01:38 PM
wolgie's Avatar
wolgie
I would tell her to start down the mountain and then jump out!!!
hahhaha, that's what I might do with mine. How many miles are on it, and is the tach doing anything weird. Does it sound like an engine problem or a suspention/brake problem.?
Old Feb 27, 2004 | 02:05 PM
ekelly's Avatar
ekelly
Yeah, thought about doing that myself but kind of like this Explorer so I want to fix it. It has 117k miles on it with a good used replacement motor done a few months ago and a rebuilt auto trans done 2 years ago. I am leaning towards suspension/brake problem since that hasn't been touched by me yet. Actually feels like the car is dragging something heavy and wants to stop! No warning lights and just had it smogged the day before this started. Any ideas?
Old Feb 27, 2004 | 08:55 PM
CarlnLola's Avatar
CarlnLola
Where is the noise coming from? Is the engine racing...that would indicate the tranny has downshifted but doesn't account for the noise?
I gotta wonder if the drive shaft is dragging. I know this sounds weird, but if the seal on the output shaft is damaged, or the output shaft bearing on the tranny is damaged, it can cause the drive shaft to drag. This might trigger the rear ABS (92's only came with rear ABS). The sensor for the ABS is in the differential. See where it might have an effect? As far as the hubs, I'm assuming you have 4WD, so I would look into the transfer case.
I'm not too savvy about transfer cases but I know that they have an affect on transmission function as they are geared together. If the transfer case slips into neutral, then the trans will feel like it's in neutral. Ergo, if the transfer case has worn or broken parts, it may cause the whole driveline to bind. Again, kinda out there but something to look at.
Keep us posted. Regards,
