92 Expoleror rotor removal
Old Feb 26, 2004 | 10:17 PM
rcthd's Avatar
rcthd
Hi,
92 Explorer front disk brake rotor
I took the wheel off to check the disk brake pads and saw the the rotor needs to be replaced ( deep groves in the pads and rotor). Do I need a special tool for removing the rotor, will a 2 or 3 prong puller work?
Will I need anything else beside the rotor? seals, bearings, while doing the rotor change?
Thanks
Rick
Old Feb 26, 2004 | 11:21 PM
mrshorty's Avatar
mrshorty
2WD or 4WD?
Old Feb 27, 2004 | 06:12 AM
rcthd's Avatar
rcthd
sorry about that .
It is a 4WD
Rick
Old Feb 27, 2004 | 07:03 AM
Opera House Works's Avatar
Opera House Works
Nothing special is needed, maybe a magnet. Been a couple years since I did it. There is a little half round key that locks the nut that isn't obvious. You tighten back with 35 ft-lb, back off and retighten to 16 INCH-POUNDS!!!!!!!!!!!! There are special tools for the nut, but I think I just used a chanel-lock.l
Old Feb 27, 2004 | 08:44 AM
rob_engineer's Avatar
rob_engineer
I just did my 93 explorer last month. All you should need is a magnet. You will see a large nut holding the rotor on. In the shaft there will be a slot. You can't see it, but there is a metal piece in that slot that prevents it from turning. A strong magnet should be placed against the slot which will draw out the locking pin. Once I removed that, the large nut was only hand tight so I didn't need a special wrench for it.
Old Feb 27, 2004 | 08:54 AM
jclj2003's Avatar
jclj2003
watch out when i had to pull mine off i had to tap the pin though the othe side loosen nut and take the pin out bc it was just stuck in thier
Old Feb 27, 2004 | 10:57 AM
rob_engineer
I was able to use the old bearing and seals which had 155,000 miles on them. No puller should be needed.
Old Feb 27, 2004 | 11:33 AM
99Xplr's Avatar
99Xplr
A simple pick set was all I needed when I had my 92. As for removing the rear seal, here's a neat trick.... take apart the front bearing and cam assembly. Then with the rear bearing still in place, put the nut back on and pull on the rotor. This will pop the rear seal and bearing. Hope that helps.... let us know how you make out.
