I am in the process of referb a 76 F150.
Just finished upgrading the 390 - new intake and 4 Bar carb.
Looks clean under the hood. Now I want to do something with the stock exhaust system. Headers, what type? and why or just replace the dual exhaust system. With What. kind of mufflers.
All advise is welcome.
wiznewski ~
I have a great time with my L&L headers dumped into 2 1/2" dual pipes pumping through Thrush mufflers. You can hear the set up at <<http://www.mistynewbeak.com/truck/truck.html>> - click the "Harrison speaks" link....I admit it's hard to hold a conversation with the wife at speeds of 75+ miles per hour. Other than that, it's a manageable rumble...
id go with some longtubes from either headman cheap but worth it. or BBK some other cheap headers. Get some 2-1/2 or 3 " exhuast into some 2-1/2 or 3" flows dumped infornt of the axles. it will have a nice rumble to it, if thats what u want.
On my '73 2wd 390 I've had Dynomax cermaic coated long tube headers ($225 in Jegs) for almost a year and I'm happy with them so far. At the same time I had 2 1/2" duals w/glasspacks installed. I really like the setup. Only trouble is the header has to be loosened for the starter removal...
