Sponsored by: Real Truck
Brite Box Lighting
Old Nov 30, 2001 | 01:26 PM
kylej's Avatar
kylej
Post Brite Box Lighting
I am thinking of installing the Brite Box lighting to my truck but was wondering if this was possibly to much for the electrical system or maybe to hot to run both high and low beams at the same time. Anyone with any info would be appreciated. Pretty dark out here in the sticks.
Old Dec 2, 2001 | 07:13 AM
RBC's Avatar
RBC
Brite Box Lighting
Hi there, I just put a BOSS plow on my truck and the plow lights are HID and are they bright, now when I use the truck lights (01 SD) its terrible on high beam. The low beam with the driving lamps is great but not on the highway for distance. Looked at the Brite Box and my thought is to go with PIAA bright whites instead. I do not think the heat build up in the lens would be any more than that running both low& high together as the bright box does and the draw would not be a concern for you relays with the PIAA I believe.
Old Dec 5, 2001 | 07:42 PM
red99sdv10's Avatar
red99sdv10
Brite Box Lighting
email me and I will send directions for a dui bright box that will cost around 12.00.
I have had it for 4 months now and most others have had it longer
the only time Ive heard of a problem is with higher wattage bulbs.
they sometime do melt the connector
Old Dec 5, 2001 | 07:45 PM
JEFFnSTL's Avatar
JEFFnSTL
Brite Box Lighting
