Transmision leak
Old Feb 26, 2004 | 06:34 AM
Zorburg's Avatar
Zorburg
Transmision leak
I have A 93 F-150 4x4 and the Trani is leaking how hard is it to change out the gaskets and are there any special tools needed
Old Feb 26, 2004 | 10:13 AM
jim henderson's Avatar
jim henderson
Depends what gaskets/seals are leaking. We need to know more.
Where is it leaking from? How much?
Some gaskets are easy to get to and replace. Others may require dropping the tranny and taking things apart. Some seals might be easy to get at, others require dropping the tranny.
Tell us more.
Jim Henderson
Old Feb 26, 2004 | 10:26 PM
Zorburg's Avatar
Zorburg
Hey jim ,the bulk of the leak seems to be coming from the back gasket they leaking just a little no puddleing to speak of .....the seels are ok
Old Feb 27, 2004 | 03:40 PM
jim henderson
If you know which model tranny you have let us know. If you don't then confirm that we are talking automatic or maybe stick.
I will take a look at my 94 F2504x4 with E4OD and also check the shop manual to make sure I understand which gasket you are talking about but I am suspecting you are talking about the gasket between the tranny and tail shaft. I have never replaced one of those so would need to take a wild guess and read the manual. Initial wild guess is the tranny can stay in the truck and you would just unbolt the tailshaft housing etc. But wait till someone comes up with a real answer.
But maybe one of the other guys with more expertise will step in. Someone probably knows the exact answer.
Meantime, I will check.
Jim Henderson
