Sponsored by: Innova
Alpine Amp Cutting Out
Old Feb 25, 2004 | 11:42 PM
epicxtreme's Avatar
epicxtreme
HI GUYS
I bought a V-power mono block alpine amp. (700 watt) and I have it running with a Sony Xplod head unit. I have all the wiring right to the amp from the battery and ground and all the others. The subs are 2 10" Sony Xplod 1100 watt peak (300 rms). My deck dosent have sub out puts so i just ran the RCA cables from the rear speaker out put for the subs. When i turn the sterio up loud and turn the bass up a bit to get them pounding they will just shut off. The amp dosent shut off because the power light is still on. They should beable to handle my amp because i only have it at about half power and its only 700 max. Does anyone know if the amp has a automatic shut off or something if it thinks its putting out to much power???? I would greatly appreciate any help from anyone that can tell me anything. I have it grounded to the frame so it cant be the ground. but thanks to anyone that can help me. hopefully hear from u soon.
Old Feb 25, 2004 | 11:50 PM
acerockola77's Avatar
acerockola77
Well first off, you should be running LOC converters if you don't have RCA outputs.
What gauge wire are you running?
Old Feb 26, 2004 | 08:43 AM
brianas's Avatar
brianas
Im confused also
are you using the rca output from the head unit
or are you using a rear speaker wire?
Old Feb 26, 2004 | 03:11 PM
bill6302's Avatar
bill6302
does the protect light come on? are the subs dual voice coil? what model amp do you have? how are the subs wired? it sounds almost like the ohm load is to low and it is going into protect.
Old Feb 26, 2004 | 03:16 PM
bill6302's Avatar
bill6302
i just looked up the subs and amp and i have a pretty good idea what you have. try wiring the subs in series so it will be an 8 ohm load. just run the positive wire from the amp to the positive on one sub, the negative of that sub to the positive of the next, and the negative of the 2nd sub to the negative on the amp. hope this helps.
bill
Old Feb 26, 2004 | 04:06 PM
LinearPower's Avatar
LinearPower
Re: Alpine Amp Cutting Out
Originally posted by epicxtreme
HI GUYS
The amp won't put out too much power, but you may be working the amp beyond it's capabilities.The Alpine V-Power that puts out 700 watts max is actually only capable of 200 watts RMS@4 ohms or 350@2 ohms. You don't say how the subs are wired, but it sounds like you may be asking too much of the amp and it is shutting itself down to protect it from burning up. It's very easy to overdrive an amp of this size. An often overlooked thing is how critical it can be as to where the amp is installed. Does it have plenty of space around it to allow for cooling? If not, and you are working the amp hard, then you will continue to experience this problem, more than likely.
Also, do you have the proper size of power cable and ground cable? The ground should be the same size as the power cable. Why not just ground to a nice unpainted spot under your carpet? Scrape if you must and place a star washer UNDER the ground point. Grounding to the frame does nothing better if the ground point isn't clean and secure.
