1978 - 1996 Big Bronco
Hard starting? check this post out!
Old Feb 25, 2004 | 04:08 PM
Capone's Avatar
Capone
For those who have posted about hard starting conditions on your Bronco or other Ford engines we have all gotten the following reasons as to why we need to crank our engines 2-3 times before it fires up....
1.clogged fuel filter
2.dying fuel pump
3.clogged injectors
4.bad AIC valve
5.bad TPS setting or sensor
6.failing Ing module
7.clogged air filter
8.clogged cat converters
9.etc etc
none of which my engine had trouble with since all of it is new.
Last week, I was filling up at the gas station...(take note that I was having intermittent starting problems....getting that click no start sound...) It was usually fixed by laying down under and smacking the poor starter....(new high torqueFord starter!) wasn't happening this time.....
Keep in mind that people wanting to fill their rides up were piling up behind me...drawing some rude comments about Fords by Chevy owners....
Well I checked the wiring and the ignition lead (12 gauge wire)
with female slot connector at the end literally fell off the connector harness......it must have been hanging on by a strand 1 atom thick!!! I jambed it into the harness and fired it right up...
I told them to try finding a fix for their chevys that fast....and of course, got no replies...
I got home and proceeded to trim, recrimp a new connector harness onto the wire with shrink wrapping to protect against accidental contacts....I snapped it into place
and I cleaned up the large gauge cable connections.
The Bronco now starts the first crank....EVERYTIME!!!!
Just a heads up!!!
Old Feb 26, 2004 | 05:39 PM
buckeyebronco's Avatar
buckeyebronco
Had a Taurus that had the same problem, easy fix once you know what it is.
Old Feb 26, 2004 | 06:08 PM
Corey872's Avatar
Corey872
Good deal...it's a great feeling to actually find the problem and fix it 100%. Every Ford I've ever had seemed to sprout some nice electric gremlins...the old Torino was always blowing fuses, AC control switches and starter solenoids, the old Escort was on fire more than once and always went through headlight switches, and I consider it an exceptional day if the tailgate motor and the 4x4 shift both work on the Bronco...now to fix that turn-signal\windshield wiper\high beam switch.
