Ammeter
Old Feb 25, 2004 | 10:24 AM
greasymonkey's Avatar
greasymonkey
Ammeter
My ammeter goes down,when revs go up.--I've checked base voltage to be `12.5v/...........no load-idle is `13.8v/........load test shows same.....so I beleive system works fine,but the ammeter instrument goes down when I rev up!!--anyone know the fix???...........thanks!!
Old Feb 25, 2004 | 12:09 PM
beartracks's Avatar
beartracks
Uh, turn it around? Seriously, is it hooked up backwards?
Old Feb 25, 2004 | 01:04 PM
Mike W's Avatar
Mike W
Yeah, the connections are reversed.
Old Feb 25, 2004 | 07:48 PM
Franklin2's Avatar
Franklin2
A good way to double check that the connections are correct, is to turn on the headlights and some other electrical loads with the truck not running. The amp guage should go to the negative side.
Old Feb 28, 2004 | 10:29 PM
greasymonkey
........I got out there finally and put on the headlights/heater/wipers/fuel pump/interior lights and saw imperceptable difference on the guage.I've got a brand new top-powered battery so it makes sense,I guess. A test voltmeter went from 12.9 to 12.1volts-------I guess I'll try a older battery?!?
Old Feb 29, 2004 | 01:06 PM
Franklin2's Avatar
Franklin2
The ammeter reads current flow, so the battery condition won't matter unless it was so dead it didn't put out anything.
I can't remember what kind of guage you have, but if you have the original Ford guage, don't worry about it. They are famous for not giving any useful info.
49willard
Jun 24, 2015 04:22 AM
DDuBB
26
May 27, 2006 07:41 PM
Narwhal
May 13, 2006 07:22 PM
cwheel
21
Jan 11, 2006 01:35 PM
illuminance72
Electrical Systems/Wiring
Oct 2, 2004 10:56 AM
