Odd Windstar problem
Old Feb 24, 2004 | 11:16 PM
Seronac's Avatar
Seronac
I have a 2000 Windstar SEL. Sometimes, when it has not been driven for a day or so, the remote keyless entry won't work, unless I place the keyfob remote right in front of the center of the windshield when I push the button (and sometimes not even then). But, after I put it on the battery charger overnight, it works fine.
I have had the battery and alternator tested and they are(supposedly) fine. Until I get it to the shop and get a computer connected to it, does anyone have any ideas or possibilities? Thanks!
Old Feb 25, 2004 | 05:06 PM
prcrboy's Avatar
prcrboy
Battery charger on the van? How was the alternator and battery tested? Sounds like you may have a weak battery or an electrical drain in the system somewhere. Does it have a volt meter in the dash and if so, what does it read.
Old Feb 26, 2004 | 11:56 AM
grizz5675's Avatar
grizz5675
Im not sure about the key fob but a lot of times if you disconnect the battery you have to reset everything because it looses memory.
