302 to 351W
Old Feb 24, 2004 | 09:30 PM
MuchToMyDelight's Avatar
MuchToMyDelight
302 to 351W
Grrr... I done a search and found nothing- although i remember this being discussed before. I know i will need a flywheel cause this one is out of an auto, and I am quite sure that my old one won't work, and my exhaust will bolt up because it is loose enough to raise it the 1.5" it will have to go up, and the motor mounts are the same. My accessories will bolt up with a longer belt (well, all i have is an alt), but i know that it cant be that simple. Are there any other flywheels that would bolt to it? I think a 289 will, but I am not sure.
Old Feb 26, 2004 | 01:07 AM
Torque1st's Avatar
Torque1st
Posting Legend
You might want to check the 351W forum. You may have seen it there. I imagine it is a common question there.
Old Feb 26, 2004 | 01:48 AM
pat67shorty's Avatar
pat67shorty
As long as the 302 that was in there is a pre 1981, it has the same 28oz" imbalance as the 351W. The flywheel will bolt on and work on your 351.
Old Feb 26, 2004 | 04:37 PM
MuchToMyDelight
I think i about got it now. But I want to use my old 302 heads for a small bump in compression and because the motor sat for a while with no intake and i can see a bit of rust on the valves, but then again, I may just break the heads down and break out the steel wool.
Old Feb 26, 2004 | 06:07 PM
mk's Avatar
mk
I don't know that you'll gain that much in compression but you will definitely lose flow because the ports and valves are smaller.
mike
Old Feb 26, 2004 | 07:20 PM
Blue Diamond's Avatar
Blue Diamond
Dual exhaust will bolt up just fine if you use the 302 exhaust manifolds. True 351W manifolds have different exit locations. If you want to run single exhaust until you can afford duals, just cut the crossover pipe in the middle and weld or clamp in a short extension pipe. The power steering pump bracket for a 351W is longer, if you can't find the proper one, get another 302 bracket (easy to find) and cut, splice and weld the two to make a longer bracket. 302 small chamber heads will bolt on if you drill the head bolt holes to the larger 351w bolt size. There is no difference between the engine mount stands and insulators.
