Im back!
Old Feb 28, 2004 | 08:20 AM
true4.2's Avatar
true4.2
5 speeds are the easiest vehicle to do burn outs in. Just do what Drizzt said. Hold the clutch down, rev to about 3000 RPM's then let up on the clutch while reving...simple.
Old Feb 28, 2004 | 12:07 PM
Drizzt's Avatar
Drizzt
just give'r
Old Feb 28, 2004 | 02:29 PM
MrBean1130's Avatar
MrBean1130
well how do you stay in one place and do a burn out.... when you dump the clutch, you jump forward while spinning the tires.
Old Feb 28, 2004 | 03:42 PM
Drizzt's Avatar
Drizzt
not if you rev it high enough, when you start feeling yourself moving forward, its time to stop the burnout and hit the brakes
Old Feb 28, 2004 | 06:43 PM
MrBean1130's Avatar
MrBean1130
ok... i guess i will just have to play with it.
Old Mar 1, 2004 | 05:07 AM
sigma's Avatar
sigma
You could always purchase line-locks to keep the front brakes engaged while doing the burnout. Line locks are electric selonoid valves that install on the brake lines. Push the pedal, flip the switch, release the pedal and your front brakes are locked and your rears are free.
Old Mar 1, 2004 | 07:27 AM
Busa01's Avatar
Busa01
Beau is talking about a continuous "line lock", whereas you can just sit and spin for 10 minutes, or until your blow up your tire. Not just a burn-out. You can't do "line-locks" with manual transmissions, at least that I know of.
However, our motors, with auto trans, are not really that powerfull enough to sit and spin for long anyway. Even with my 4:10 gears and smaller tires, I could only spin for about 5 or 6 seconds before my tires would warm up to the point where they would just grab and the spin would stop. Depends on the tire alot too. Cheap plastic tires will spin alot more than expensive sticky silicone ones.
Old Mar 1, 2004 | 11:19 AM
sigma's Avatar
sigma
Tom,
Line locks go on the brake lines and can be installed on either automatic or manual transmissions. You can install them on the front brakes, back brakes or both. If you install them on the front brakes, you can burn-out while sitting in place. It’s almost the same thing as holding down on the brakes and flooring it with an automatic. In fact it’s better because you don’t have to fight the rear brakes to break em loose. They also work as a killer parking brake.
Years ago, I put line locks on a 1976 Ford with a 351M and I could light up my N50 radial TA’s and leave 20 inch wide black marks on the road. It was great fun!
Old Mar 1, 2004 | 11:24 AM
Busa01's Avatar
Busa01
Hmmm,
And all this time I just thought the term "line lock" was an expression for applying your brakes and gas at the same time.
That would be great to have them on the front only!! Once you've got them installed, how do you apply them? Like your parking brake? You have to install a separate lever inside your cab like your parking brake?
Interesting. See, I STILL learn something new every day
Tom
Old Mar 1, 2004 | 11:44 AM
sigma's Avatar
sigma
No extra pedal or lever, the device itself is simply a small electric solenoid valve controlled by an electric push button. To apply you simply step on the brake pedal then push the button (usually mounted on the shifter). Once energized, the valve closes and holds pressure in the brake line and keeps the front brakes locked up after you let off the brake pedal. Now the front brakes are locked up and there is no braking force on the rear end so the tires will spin fairly easy when you drop the clutch and floor it. When you are ready to go you just push button again, the line locks release and away you go.
These things are quite popular with Drag racers and hard-core 4x4 enthusiasts.
There are several manufacturers for line locks. The ones that come to mind are Hurst, B&M, Biondo.
Old Mar 1, 2004 | 11:49 AM
Busa01's Avatar
Busa01
That's pretty cool. Now the manual trans guys can do line locks also. But why would an off-road enthusiast desire one of these, so he can spin himself down into the mud and get stuck?? (sounds like something I would do!!)
also, where've you been sigma? You disapeared for a while.
Tom
Old Mar 1, 2004 | 11:56 AM
sigma's Avatar
sigma
Nope, so he can have a parking brake that will hold the truck on a steep hill. It also works really well to prevent rolling backward when starting on a steep hill.
Old Mar 1, 2004 | 12:01 PM
  #28
Busa01's Avatar
Busa01
ah, capice!! Comprende!! I understand now.
One question though....what's a "hill". I live in Florida and I don't think I've ever seen one of these things. Can I get more horsepower if I install one?
Old Mar 1, 2004 | 12:07 PM
  #29
sigma's Avatar
sigma
Ha Ha! The only hills in Florida are closed landfills.
Old Mar 1, 2004 | 12:18 PM
  #30
Busa01's Avatar
Busa01
filled with water!!!! some really great muddin' out here though
