Heater motor switch
Old Feb 24, 2004 | 08:28 PM
doc_nomad's Avatar
doc_nomad
Heater motor switch
My heater motor switch only works on high, any suggestions. How is the low, med, high controlled on these.
Old Feb 24, 2004 | 08:57 PM
pursable's Avatar
pursable
I just fixed this in my 93 f150, its the resister under the hood mounted in the blower housing next to the blower motor. Mine was mounted to the right of the blower motor. I picked a new resister up from the ford dealership for about $17.00. Pull the plug out and two screws hold it in the housing it was really simple to replace. Hope this helps
Old Feb 24, 2004 | 09:02 PM
kioolt's Avatar
kioolt
The current for all of the speeds except high is limited by a resistor in series with the blower motor. When the resistor opens up (no continuity) the only speed you will have is high speed when the selector switch is set to high. All of the other speeds will not work at all.
Old Feb 24, 2004 | 09:39 PM
doc_nomad's Avatar
doc_nomad
Thank you very much, I had an idea it was something like that but I did not have any idea where to find the resistors. I do not yet have a repair manual.
Old Feb 25, 2004 | 09:03 PM
Fully_Loaded's Avatar
Fully_Loaded
When you pick up your resistor pick up the repair manual they are very helpful in troubleshooting
Old Feb 26, 2004 | 08:07 AM
gvlawncare's Avatar
gvlawncare
It might be worth it to change the wiring pigtail that goes to to resistor too. While you're at it.
