How do i know which o2 sensor is bad with a bad sensor code???
Old Feb 24, 2004 | 06:17 PM
ssilvern's Avatar
ssilvern
if my code was PO130 - PO135, those are all "bank no 1 Sensor no 1" which is number 1? anybody? anybody??
truck
97 expy 5.4l vin L
thanks in advance.
Old Feb 24, 2004 | 07:13 PM
FTE Herman's Avatar
FTE Herman
Bank 1 is the passenger side of the vehicle and the sensors are numbered from nearest the engine to furthest.
Old Feb 24, 2004 | 07:23 PM
ssilvern's Avatar
ssilvern
so the sensors on the air box (where the filter is) is not 1 and 2? or would they be 3 and 4?
Old Feb 24, 2004 | 07:38 PM
FTE Herman's Avatar
FTE Herman
I'm sorry, the O2 sensors are in the exhaust, after the manifolds. Crawl underneath and have a look. Number one is upstream of the cat and number 2 is after the cat. The sensors on the air box (to my knowledge there is only one) would be IAT (Intake air temperature) and MAF (Mass Air Flow).
Bank 1 is passenger side bank 2 is drivers side. Number 1 is upstream (before the cat) between the manifold and the cat and number 2 is downstream from the cat.
Old Feb 24, 2004 | 09:30 PM
pspower's Avatar
pspower
The downstream sensor is a monitor.Your 02s11 is right side sensor before cat
Old Feb 24, 2004 | 09:35 PM
FTE Herman's Avatar
FTE Herman
PSPower: is it different on a Navi than an Expy? I though I remembered four, two before and two after?
Old Feb 24, 2004 | 10:42 PM
buzzard's Avatar
buzzard
There are 4 sensors, but only two affect engine performance. The second two, downstream, only monitor the cats performance.
Old Feb 25, 2004 | 10:46 AM
ssilvern's Avatar
ssilvern
thanks alot guys. i really appreciate the help. you are all life savers
