Timing?
Old Feb 24, 2004 | 04:27 PM
Randyb12's Avatar
Randyb12
Timing?
If I want 34 degrees of total timing what should I set the inital timing at. I am useing the stock Duraspark dist. with a MSD 6AL box.
Old Feb 24, 2004 | 04:48 PM
Ratsmoker's Avatar
Ratsmoker
Hey Randy, ford used many different advance cams in their distributors. You will have to take the baseplate off and figure out which advance cam you are running. It will say something like 15L or 18L. Mulitply this number by two and you will have the total amount of mechanical advance the distributor will give you.
I had the 18L and it sucks bad! You have almost no initial and too much total advance when you get it set at a decent setting.
The 13L seems to be the hot ticket for performance FEs.
Old Feb 24, 2004 | 06:42 PM
Randyb12's Avatar
Randyb12
Thanks, I will check it out.
