1978 - 1996 Big Bronco
pass. door latch
Old Feb 24, 2004 | 02:54 AM
okacookie's Avatar
okacookie
pass. door latch
my passenger door switch will no lock or unlock the doors but i can still unlock them with the drivers side switch. is this just a bad switch. what do i need to replace? also my drivers side lock makes a loud buzzing noise when i press lock. what is this? thanks for the help.
chris
Old Feb 24, 2004 | 06:04 AM
kaised's Avatar
kaised
Does the pass. door have any play in it? I fixed this problem by adjusting the striker bolt so the door closed tight and pushing half a can of WD40 into the latch and lock mechanism.
Old Feb 24, 2004 | 10:13 AM
BillyBob69's Avatar
BillyBob69
The buzzing noise sounds like the door lock actuator is going out. As for the pass switch not working, it could be something as simple as a broken wire. Mine was the opposite of your...drivers wouldnt work at all and the passenger side would only unlock...and only if you pushed it to the lock position. I replaced the switches and still nothing. So i started tracing the wires with a meter and a wiring schematic...found a broken wire in the rubber boot that goes from the door to the fender on the drivers side. If you need a diagram post back and I will post a link to where you can view it and print it up.
Old Feb 24, 2004 | 10:37 AM
okacookie's Avatar
okacookie
thanks for the help i will try that. would you mind sending me the wiring diagram. thanks
Old Feb 24, 2004 | 10:40 AM
BillyBob69's Avatar
BillyBob69
What year truck?
Old Feb 24, 2004 | 02:59 PM
okacookie's Avatar
okacookie
my bronco is a 1994 xlt
Old Feb 24, 2004 | 03:21 PM
BillyBob69's Avatar
BillyBob69
ok this is irking me..... lets try this link....
http://www.imagestation.com/mypictur...3&from_album=1
Old Feb 24, 2004 | 03:26 PM
BillyBob69's Avatar
BillyBob69
OK that worked...scroll down a bit and you can get the larger version...or just enlarge the one you see.
Old Feb 24, 2004 | 04:15 PM
okacookie's Avatar
okacookie
thanks a lot that should help me track down the problem...i hope
Old Feb 24, 2004 | 09:51 PM
BillyBob69's Avatar
BillyBob69
Just remember..its hard to tell but the passenger side is the master side of the circuit. Hope you get it worked out
Old Feb 25, 2004 | 12:38 AM
okacookie's Avatar
okacookie
oh yeah about the lock actuator. i have owned the truck for over 2 years and it has made the noise since i got the truck. if it was the actuator wouldnt it have stopped working if it was going out. i was just wondering. thanks for the help
Old Feb 25, 2004 | 09:50 AM
BillyBob69's Avatar
BillyBob69
Not really. I have a window motot that has been working at half speed for 4 yrs now. And the holes have already been drilled for me too. It has been replaced before. But it still works.
