Limited slip codes?
Old Feb 24, 2004 | 01:49 AM
ACESN8S's Avatar
ACESN8S
Limited slip codes?
What years and what codes do I need to look for to find a LS or Traction Lock?
I already posted in the tranny/rear section and didn't get much of a look-see.
So I am hoping somebody in here might be of assistance.
Thanks
Old Feb 24, 2004 | 08:33 AM
banjopicker66's Avatar
banjopicker66
The answer is all of them. Including the cars, if you have a Ford 9" rear. Look for the "L" stamped on the tag on the second line, right after the ratio number. For example, 3.00 L xxxx will tell you that you have a 3.00 ratio locker.
Good luck.
Old Feb 24, 2004 | 10:10 AM
ACESN8S's Avatar
ACESN8S
great, thanks.
Old Feb 24, 2004 | 10:41 AM
MuchToMyDelight's Avatar
MuchToMyDelight
I would think that it is safe to assume that all Lincoln LSs had limited slip, but I am not sure.
