Modular V10 (6.8l)
3v V10???
Old Feb 23, 2004 | 11:13 PM
DNabs11's Avatar
DNabs11
3v V10???
Hello,
Am going to buy a 2004 V10 350, but heard there may be a 3V version coming out at some point. Just wondering if there was any truth to this? If so, maybe I will wait. Thanks
Dave
Old Feb 24, 2004 | 12:15 AM
Chaps's Avatar
Chaps
Yup, 2005's
Old Feb 24, 2004 | 09:52 PM
bigdawg460's Avatar
bigdawg460
Originally posted by Chaps
Yup, 2005's
Any word on the power ratings?
Old Feb 24, 2004 | 10:13 PM
Chaps's Avatar
Chaps
350 hp, 455 torque is what has been floating around the rumor mill
Old Feb 26, 2004 | 10:56 PM
dlj31's Avatar
dlj31
Dosent seem like much of an improvement for a major head revamp, mabye it will improve the fuel miledge.
Old Feb 26, 2004 | 11:53 PM
Berol's Avatar
Berol
It will probably improve the the flatness of the torque curve, even though the current one is dang good. They'll do this by including the variable valve timing, similar to the 3V 5.4L in the 150's.
Old Feb 29, 2004 | 04:41 PM
bdjupiter's Avatar
bdjupiter
Just curious where you all heard about the new 3V V10. I have looked around but haven't been able to find anything on it.
Old Mar 12, 2004 | 04:37 PM
deckofwood2002's Avatar
deckofwood2002
we do some limited durability tests on all the mod motors and find it always a pain in the a-- to remove the spark plugs.currently i removed my rubber boot from an extra 5/8 socket and stuffed it into a 9/16 socket,works good but does anyone make a specific socket for this?we also do drop testing right now on the v10 -3v.checking the integrity on the engine removal brackets.
Old Mar 22, 2004 | 01:14 PM
1956MarkII's Avatar
1956MarkII
I feel like an idiot asking this, being a DEALER and all, but where are you folks getting the info on the new V10? Ford tells us dealers NOTHING; I thought maybe someone posting here works at the engine plant, or is doing development work on this new motor. Any confirmed info would be greatly appreciated!
Jeff
Old Mar 23, 2004 | 02:13 AM
wbarber_07458's Avatar
wbarber_07458
Jeff
The first I heard of it was from a post on the dieselstop some months back. The guy there mentioned he saw it in some Ford marketing material he had received. The numbers quoted there were the same I saw earlier in this thread. I never did ask him what marketing material he was talking about - not sure how official it was.
Bill
Old Mar 23, 2004 | 04:07 AM
Monsta's Avatar
Monsta
Sit. Stay.
I heard about it through Blue Oval News "dot" com.
I tend to take a lot of the "rumors" with a grain of salt.
I'm sure Ford will do it (3V V10). Certainly makes sense. The numbers that I see floating around are the same exact increase in output when the 5.4L got new heads. However, the new 5.4L has a new BLOCK & exhaust, too.
I'm sure the heads gave it most of the increase but the whole engine was basically redesigned. Can't imagine the V10 undergoing such as redesign since they only sell a small fraction of V10s compared to the 5.4 V8.
But who knows...I still wait with baited breath.
Old Mar 26, 2004 | 02:53 PM
deckofwood2002
the biggest issue we have with the 6.8l is the fly by wire throttle and they burn up the trannies too quick.i was under the impression the ratings were 370 hspr/455 torque.find out late this year or early next i suppose.
Old Mar 26, 2004 | 06:38 PM
Monsta's Avatar
Monsta
Sit. Stay.
HUH???
Old Mar 26, 2004 | 06:45 PM
DJR 17's Avatar
DJR 17
It looks like the 4.6 is going to get the 3v treatment first. No sign anywhere of the V-10 3v. So far it's just a rumor. Here is something I found on the new 3v plant... http://www.allfordmustangs.com/artma...icle_198.shtml
Old Mar 27, 2004 | 02:51 AM
deckofwood2002
6.8l 3v
the throttle is electronically controlled and it's always a headache when we set any of the modular engines up(3v 4.6,5.4 AND 6.8l)because the processors are not calibrated correctly which we have to have a ford engineer come out and correct the problem(always processor related)and we do not have dyno's in durability but we do use trannies.we use the tran. to mock it up in the engine cradle -the trannies are engaged at a idle speed for a short time which the clutches slip,blah,blah,blah.the trannies don't last half as long as they do behind the other modular engines due to the 455 lbs. torque.no.i can't really prove any of this without losing my job so don't ask me where i work.it's coming though in 2005 in the E SERIES AND F-SERIES TRUCKS/VANS.
