Distributer search
Old Feb 23, 2004 | 11:09 PM
mcgruff764's Avatar
mcgruff764
Distributer search
I'm in the process of fitting a 5.0L from a 93 Mustang in my 1981 F-100 Stepside. The truck came stock with a 300 CID 6 cylinder so I have had to hunt for parts. Right now I am having trouble finding a distributer that will work. The stock FI distributer looks simalar to a vacuum advance distributer I pulled from an older engine EXECEPT the shaft below the drive gear is longer on the newer distributer. I know this runs the oil pump but how much of a difference does the longer shaft make? Can I run the distributer with the shorter shaft or can someone suggest an acceptable replacement that won't cost an arm and a leg?
Old Feb 23, 2004 | 11:36 PM
Mil1ion's Avatar
Mil1ion
Why not get a dizzy from an 80's/90's 302 EFI Truck
Old Feb 24, 2004 | 09:20 AM
mcgruff764's Avatar
mcgruff764
Do you think that an 80/90 model efi truck will have a vacuum operated distributer with the long oil pump drive? That will be excelent if it does.
